1994 Toyota Corolla Overheating
CHAJIS
  • 1994 TOYOTA COROLLA
Engine Cooling problem
1994 Toyota Corolla 4 cyl Two Wheel Drive Manual
When I was going uphill in atraffic jam, my car temperature gauge suddenle shot up and the engine was very hot making the engine coolant started boiling, I changed the rubber valves but still the engine is still overheating at a very abnormal rate. What could be the possible cause?
Do you
have the same problem?
Monday, August 23rd, 2010 AT 2:37 AM
Try replacing the thermostat and go from there.
Monday, August 23rd, 2010 AT 2:47 AM
Recommended Guides
