Engine idle is low and vibrating
JUJUKEMIST
  • 1994 TOYOTA COROLLA
Engine Performance problem
1994 Toyota Corolla 4 cyl Front Wheel Drive 98645m miles
my toyota 94 corolla, drags sometimes, as if the engine is not combusting well.
Sometimes after starting, it idles at 750rmp with minor vibrations
Do you
have the same problem?
Thursday, October 29th, 2009 AT 4:13 PM
MMPRINCE4000
  • EXPERT
When was last tune up and timing belt change?
I would also check timimg, 10 degrees BTDC.
The idle is within range.
It is also possible the transmission is causing the problem, check fluid level in trans (engine running) and also check differential fluid level.
Look at CV axle seals in transmission and check for leaks, if leaking your differential fluid level may be low.
Friday, October 30th, 2009 AT 9:18 AM
Recommended Guides
