1993 Toyota Corolla Injectors
GHATMAIL
  • 1993 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 106,000 MILES
My Corolla's injectors seal (which are saw like a rubber ring(not little O-ring) on the injectors in holes which they are entered in their manifold) are a little cracked and after many years lost their elasticity.
Around 2 of 4 of injectors on the injectors manifold we can see gasoline mark around injector entrance hole on the manifold. I've never seen even a little drop of gasoline, just see the gasoline mark(Like the mark of gasoline vapor).
Question is: is this dangerous for motor? I mean will be this gasoline mark(like gasoline vapor mark) on the manifold dangerous for catch fire or it is not very important? And why just 2 of injectors makes this vapor mark?(Despite all the injectors sealing rubber rings are a little cracked)
Thank you very much
Hatam Ebrahimi
Do you
have the same problem?
Monday, January 4th, 2010 AT 4:10 AM
MMPRINCE4000
  • EXPERT
Anytime you have a gas leak, you have the risk of fire.
Just remove the fuel rail and replace the seals.
The fact that 2 are leaking and 2 are not is just luck.
Monday, January 4th, 2010 AT 8:33 AM
