Fuses & relay location
BERSYL671
  • 1992 TOYOTA COROLLA
  • 4 CYL
  • FWD
I have a 1992 toyota corolla LE and im trying to find a certain relay and fuse. May I get the Diagram for FUSES & RELAY locations. THANKS.
Saturday, April 30th, 2011 AT 10:43 PM
KHLOW2008
  • 41,815 POSTS
I have attached whatever diagrams I could find on the fuses and relay boxes and guides to help you test them
and
Sunday, May 1st, 2011 AT 12:31 AM
LCRIVERA
  • 6 POSTS
  • 4 CYL
  • FWD
  • 100,000 MILES
My son has a 92 toyota corolla and there appears to be something shorted and draining his battery. I initially thought that this would be easy to find and was proven wrong. With the car turned off, I put a current meter in series with the battery and found that there was imitially 700 mA of current being drawn with everything turned off. I proceeded to remove every fuse in the fusebox one by one and was expecting to see the current disappear when I came across the faulty circuit. I removed every fuse one at a time while checking the current draw and found the current still there. I also removed all fuses in the 2 fuse boxes next to the battery to no avail. There is a bank of threee square fuse looking things right at the positive cable that I could not remove. Any ideas as to how I can properly troubleshoot this. The current was drawing a little over 1 amp after I finished removing all fuses. Finding the source of 1 amp should be easier to find than I am expecting! Please help!
Thanks.
Carlos
Monday, April 1st, 2019 AT 1:07 PM (Merged)
Those little squared looking things are the fusible links-
Now did you remove all the fuses in the fuse block-if so disconnect the alternator-is the draw still there?Get back to me
LCRIVERA
  • 6 POSTS
Removed every fuse 1 by 1. I will do that this evening when I get back from work. Could be the diodes in the alternaotr going bad right?
Thanks again,
Carlos
Yes-Sir that's the last place-Diodes
LCRIVERA
  • 6 POSTS
A break in the rain here in the Bay Area! I went out this morning and found that it is not the alternator
The battery was disconnected from the negative post since the last check (few days).
The only thing that I opened was the hood (doors closed) and hooked up the meter in series with the negative post. This time the current draw was 4.1 amps. Last check it was 1 amp! I proceeded to disconnect the alt (2 places) and the current draw remained the same. After about 5 minutes, the current started to get lower and stabilized at 2 amps. I opened the door and this time removed all the fuses and the current remained the same at 2 amps. Out of curiosity I turned on the lights and the current draw went to 9 amps.
Any other suggestions?
Thanks,
Carlos
Out of curiosity I turned on the lights and the current draw went to 9 amps. Of course its gonna be higher-your loading it.
Disconnect it again and this time put a test light in between-and restart removing the fuses.
Amperage draw allowable is only 0.30 milliamps. Set the amp scale in millamps.
LCRIVERA
  • 6 POSTS
The current draw was initially 4 amps and it dropped to 2 amps. This is with all the fuses OUT of the box.
I am using a Fluke 8010A Multimeter
This has 2 modes (scales)
Scale 1 is the 2000 mA (2 AMP) Scale and this has a fuse.
Scale 2 is the 10000mA (10 AMP) Scale with no fuse.
This morning I put the meter on the 2 AMP scale since I previously measured 1 amp (1000 mA) and it blew my 2 AMP fuse. I realized it was drawing higher so I put the leads on the 10 AMP scale and that is where I get the 4 amps from.
Again, this is with all the fuses removed and still out of the box.
CR
LCRIVERA
  • 6 POSTS
Ok, I removed the fuseable link from the battery and of course the current draw went to zero. I then removed the nut holding the wire to the blue FL. I then touched the wire to the post and the current draw is in the mA's
I then removed the nut going to the pink FL and the middle came tords me. I touched the main wire (Black with a red stripe and the current draw is 2 amps. This black wire the red stripe is what is leading to the short. Any idea as to where this wire goes? Is there a wiring diagram on line that I can get it from?
Your inputs are greatly appreciated.
CR
Black with a red stripe and the current draw is 2 amps. Is this the wire with the 100amp fuse. If so disconnect/remove all the wires from the alternator and see what happens.
LCRIVERA
  • 6 POSTS
I traced this wire to the back of the engine going to the bottom. As I traced the wire down I noticed that the current draw came down to less than 150 mA!1
I couls feel that the wire was bare at the end and was shorting to something. I felt around and moved it away from everything and slopped some silicon RTV around the bare wire. I will wait till the weekend to lift the car up and see exactly what was shorting. In the meantime, everything looks normal now!
Thanks again for your inputs,
Carlos
