1989 Toyota Corolla water level
SAM BAKKER
  • 1989 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 255,864 MILES
The water level drops a little bit and ther some times is coolant on the ground under the raidiator the car dosint over heat at all ther is no oil or grime under the radiator cap ether.
Do you
have the same problem?
Thursday, April 24th, 2008 AT 7:03 PM
Get it pressure tested to find where that leak is.
Thursday, April 24th, 2008 AT 7:19 PM
Recommended Guides
