1989 Toyota Corolla car has a real bad miss
BGMATIS
  • 1989 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 121,850 MILES
What can cause the car to miss or run badly after I have changed the spark plugs and wires. I have put in new plugs and wires at least 3 times this month. The car is still running ruff. The timing has also been checked. What else can I try.
Do you
have the same problem?
Saturday, June 28th, 2008 AT 1:15 PM
KHLOW2008
  • EXPERT
Hi bgmatis,
What is the misfiring like? Hard acceleration? Idling etc. At what rpm most noticeable.
It could be the injectors, distributor + coil and also bad compression.
Sunday, June 29th, 2008 AT 5:28 AM
BMRFIXIT
  • EXPERT
Check the tune up do a compression test
firing order 1342
Have an automotive repair question!
Sign up and ask your automotive question !
http://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Sunday, June 29th, 2008 AT 5:35 AM
Recommended Guides
