1987 Toyota Corolla engine wont start
JCHAP005
  • 1987 TOYOTA COROLLA
Engine Mechanical problem
1987 Toyota Corolla 4 cyl Front Wheel Drive Manual
engine cranks but will not start, checked fuses and relay. Verified that fuel is getting to the carb.
Do you
have the same problem?
Monday, January 12th, 2009 AT 8:25 PM
BMRFIXIT
  • EXPERT
Check for spark
check timing belt
Monday, January 12th, 2009 AT 9:01 PM
Check for spark then comeback
Monday, January 12th, 2009 AT 9:06 PM
JCHAP005
All four plugs are getting spark. I think it may be timing but not sure how to do it.
Tuesday, January 13th, 2009 AT 9:40 PM
Check the fuel pressure and comeback with the readings before we go into valve and ignition timing
Wednesday, January 14th, 2009 AT 4:20 AM
JCHAP005
How? Where?
Wednesday, January 14th, 2009 AT 10:37 PM
Get a fuel pressure tester hook it up on the fuel rail test port turn key on and record the pressure then start the vehicle and record the running pressure.
http://www.2carpros.com/forum/automotive_pictures/12900_fuel_pressure_system_circuit_8.jpg
Thursday, January 15th, 2009 AT 2:46 PM
JCHAP005
Vehicle will not start and there is no fuel rail it is not fuel injection.
Thursday, January 15th, 2009 AT 7:15 PM
Disconnect the fuel inlet on the carburetor hook your fuel pressure tester and give me the readings.
Friday, January 16th, 2009 AT 12:54 AM
JCHAP005
The car is fixed! I found a fuse box located on the battery cable that for some reason didnt notice berfore. It was a 60 amp fuse.
Thanks for your help
Saturday, January 17th, 2009 AT 10:42 PM
Recommended Guides
