1983 Toyota Corolla mis fire on engine
SANESH
  • 1983 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 288,852 MILES
Hi I have toyota corolla 1.3l 4k motor. I recently changed the starter. After a few swings it starts. Does not start instantly. Now I notice the car misfiring. I have bought new lead cables, what could be causing this
Do you
have the same problem?
Wednesday, May 19th, 2010 AT 6:37 AM
MMPRINCE4000
  • EXPERT
Check spark plugs for fouling, and if wires are original, replace them.
Wednesday, May 19th, 2010 AT 7:20 AM
SANESH
I have check the plugs, I doubled checked the gaps, but still no good
Thursday, May 20th, 2010 AT 1:34 AM
MMPRINCE4000
  • EXPERT
Possibilities are ignition coil, or ignition module, vacuum leak.
Or could be mechanical, bad valve, low compression.
Thursday, May 20th, 2010 AT 8:25 AM
Recommended Guides
