1990 Toyota Celica won't start
RJMAURIGI
  • 1990 TOYOTA CELICA
Engine Mechanical problem
1990 Toyota Celica 4 cyl Front Wheel Drive Manual
when I try to start the car I get nothing. I pump the clutch and here the starter relay making I charged the battery and I can jump it off. Is it possible that my battery doesn't have enough cold cranking amps(500) or is possible that the alternator is not recharging the battery?
Do you
have the same problem?
Thursday, October 2nd, 2008 AT 3:34 PM
Get the battery and alternator load tested-if it checks out-troubleshoot the ignition switch/clutch switch/starter relay and starter itself see below diagram
http://www.2carpros.com/forum/automotive_pictures/12900_st1_20.jpg
http://www.2carpros.com/forum/automotive_pictures/12900_st2_18.jpg
Thursday, October 2nd, 2008 AT 4:02 PM
Recommended Guides
