Toyota Camry problems
LEVI21
  • 1989 TOYOTA CAMRY
  • 2.0L
  • 4 CYL
  • FWD
  • 130,000 MILES
The car will start run for maybe 30 seconds then dies like it is running out of gas. It is like it is running that you feel that is in the fuel line out. Then it dies but I can start it right back up and it does the same thing
Do you
have the same problem?
Sunday, March 26th, 2017 AT 7:19 PM
CATAFINA
Try checking the fuel pressure for a start: https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator, then let me know so we can continue to troubleshoot
Sunday, March 26th, 2017 AT 11:53 PM
HMAC300
  • EXPERT
Try a security system reset they shut off fuel and or ignition if it engages. that causes issues like yours. see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Monday, March 27th, 2017 AT 6:28 AM
CATAFINA
Also check and test the TPS and MAF sensor
Monday, March 27th, 2017 AT 1:52 PM
Recommended Guides
