MY CAR IS OVER HEATING
SG2007
  • TOYOTA CAMRY
IS A 1989 TOYOTA CAMRY 181,000 MILES 4 CYLINDERS THE CAR STARTED OVER HEATING THE FANS ARE NOT WORKING THE ONLY WAY THE FANS WILL START IS WHEN THE AC IS TURNED ON. I HAVE REPLACED THE THERMOSTAT, THE THERMOSTAT CENSORS, RELAY CENSORS AND IT DIDNT WORK. SO I HAD THE RADIATOR FLUSHED IT DIDNT WORK THEN I HAD THE RADIATOR REPLACED AND THE ALTERNATOR BUT NOTHING HAS WORKED. WHAT ELSE CAN BE DONE
Do you
have the same problem?
Friday, August 31st, 2007 AT 8:38 PM
What is it a 2.0L or 2.5L engine? Check the fusible link RDI fan 30amp/radiator fan high pressure switch and temperature switch.
Saturday, September 1st, 2007 AT 4:45 AM
SG2007
[quote="rasmataz"]
THE ENGINE IS 2.0 do the following its for a 2.0L
Saturday, September 1st, 2007 AT 9:56 AM
Recommended Guides
