2004 Toyota Camry REPLACING CABIN AIR FILTER
MOREXZ1
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 49,000 MILES
HOW TO REPLACE MY CABIN AIR FILTER?
Do you
have the same problem?
Tuesday, February 23rd, 2010 AT 3:13 PM
CABIN AIR FILTER REPLACEMENT
1. Open the glove box. Remove the screw with a Phillips-head screwdriver and slide the hook as shown.
2. Push each side of the glove box to disconnect the claws.
3. Remove the filter case from the filter outlet.
4. Remove the filter from the filter case.
5. Inspect the filter on the surface. If it is dirty, it should be replaced.
Installation
Reverse removal procedure.
Tuesday, February 23rd, 2010 AT 4:14 PM
Recommended Guides
