Airbag light on?
AELLIOTT1102
  • 2011 TOYOTA CAMRY
  • 4 CYL
  • TURBO
  • 160,000 MILES
My slip indicator light will not go off and now my airbag light came on. How can I turn them off?
Thursday, April 12th, 2018 AT 9:25 AM
  • 31,938 POSTS
You need to run a diagnostic code check and see what codes are set, this will indicate what is at fault, run the scan. If the lights are on, there will be codes set. You will have to get a scanner that will read the SRS and traction control systems, simple generic scanners may only cover engine codes. It sounds like the clock spring behind the steering wheel is out but to be sure lets run the codes by following this video.
https://youtu.be/gnSGfEqrf_w
Friday, April 13th, 2018 AT 12:23 AM
AELLIOTT1102
It was the clock spring thanks for the help this site is amazing!
Friday, April 13th, 2018 AT 5:01 PM
  • 31,938 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Friday, April 13th, 2018 AT 5:17 PM
CYNTHIA SASAOKA
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 87,680 MILES
How do you turn off the air bag light?
Wednesday, January 13th, 2021 AT 9:22 AM (Merged)
MASTERTECHTIM
  • 4,749 POSTS
You cant turn off the light. unfortunately you have to fix the problem. every time you start your car it does a entire check on your srs system and if there is a problem the light will remain on.
here is how you get the codes to see whats wrong
MRWILSON26
The clock spring was bad in my car cost me $167.00 for the part and I had to remove the steering wheel.
SMITHRON1944
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • 48,000 MILES
The little red airbag indicater malfunction light won't go off. Can this be reset?What would cause this? Expensive fix?
Wednesday, January 13th, 2021 AT 9:23 AM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi smithron1944,
Thank you for the donation.
When the airbag indicator shows, an error in the airbag system has been detected and you need to retrieve the trouble code to find out which component is malfunctioning.
The cost would depend on what needs to be done.
Would you be able to perform basic diagnostics if I provide you with the procedures? Air bags systems are sensitive and accidental deployment can happen if mistakes are made.
CARGUESTIONS
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • 220,000 MILES
My airbag light in dashboard came on and stays on. I was asked by a relative of mine who had same problem, if my horn still blows and I said yes. He said he took his vehicle to a mechanic that told him it was the Clock Spring located in the steering wheel that needed to be replaced. He ordered one from Amazon and paid $50.00 for it. The mechanic replaced it for him and that fixed the problem. Can I assume that is what is causing mine to stay on because his vehicle was not a 2004 Camry four cylinder with 220,000 miles like my car but his is a Toyota?
  • 52,797 POSTS
Good morning,
No, you cannot assume it at all.
There is a fault code set for the system and you need to get the fault code read so we can narrow the area of failure.
It would be an expensive guess if it is not.
A part store and read the code for free. When you get the code, let me know so we can continue.
SJISHAQ
  • 14 POSTS
  • 1996 TOYOTA CAMRY
  • 125 MILES
I have a 1996 Toyota Camry. It has the airbag light on. I accidentally pulled out the SRS fuse and the light came on. The airbags have not been deployed. How can I reset the airbag light without going to the dealer and spending money? I tried to take the battery out and it still didn't work, the negative and positive/ negative for one day each.
Thanks
Syed Javed
Wednesday, January 13th, 2021 AT 9:27 AM (Merged)
You don't clear the codes when the system is working they clear themselves. Here is a video to help see what's going on. 0 times out of 10 it will e the clock spring behind the steering wheel.
SJISHAQ
  • 14 POSTS
You were right the clock spring shorted out the new one works with no light on.
Thanks
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
SJISHAQ
  • 14 POSTS
  • 1996 TOYOTA CAMRY
  • 125 MILES
I accidentally took out the SRS air bag fuse and then I putted it back on and now the sign is on and wont go away so what should I do.
Wednesday, January 13th, 2021 AT 9:29 AM (Merged)
  • 31,938 POSTS
Get a scan done just to check what the code is, also make sure that the fuse was not blown, test it with a multi meter just to be sure.
SJISHAQ
  • 14 POSTS
The fuse is okay. I don't want to go to the dealer
  • 31,938 POSTS
With a good scanner you can check it here is a video
SJISHAQ
  • 14 POSTS
I checked it with a mechanic and the mechanic says you need to reset the light. The mechanic doesn't know how to reset the light. Can you please tell me how to do this at home.I really don't want to go to the dealer because last time I went there they messed up my car.
  • 31,938 POSTS
You can't just re set the light, this is a fault code and the problem must be fixed first, the code will identify the problem, doing a re set will do nothing, the light will come on straight away, what is the code, get a scan done and tell me so I can assist.
