2003 Toyota Camry replacement
JANEESH.E
  • 2003 TOYOTA CAMRY
Air Conditioning problem
2003 Toyota Camry 4 cyl
freezer replacing
Do you
have the same problem?
Thursday, May 14th, 2009 AT 5:57 AM
MMPRINCE4000
  • EXPERT
AC systems are best repaired at a qualified repair shop. The freon must be contained and not vented to atmosphere, and generally if they are not working, there is a leak in the system.
I know in this economy everyone is trying to fix problems themselves, but you can wind up overfilling the system and causing compressor failure, which can cost up to $1,000 or sometimes more.
Thursday, May 14th, 2009 AT 6:27 AM
Recommended Guides
