2002 Toyota Camry engine light on
SLARA
  • 2002 TOYOTA CAMRY
Engine Mechanical problem
2002 Toyota Camry 4 cyl Automatic 70300 miles
I have taken my 2002 Camry into the dealer at least four times with the same problem which is the engine light keeps turning on. The first time I took it they said, it was the O2 sensor, the 2nd a wire was loose, the third they rewired the the O2 sensors, and the fourth time they called toyota to find out what was causing the light to come on. When I left the dealer there was no problem the light did not come on at all for 3 days and everytime I take it in they do a diagnostic test and the same thing pops up it's the O2 sensors. I have open and closed the gas cap thinking it may not be closed tight enough, but still the light is on. Anyone have any ideas as to what could be causing this?
Do you
have the same problem?
Monday, May 5th, 2008 AT 2:09 PM
SERVICE WRITER
  • EXPERT
What are the code numbers shown?
Monday, May 5th, 2008 AT 4:02 PM
Recommended Guides
