Cabin air filter replacement
SINBADTIBURON
  • 2001 TOYOTA CAMRY
  • 6 CYL
  • 75,000 MILES
How I replace a cabin air filter in Toyota Camry?
Do you
have the same problem?
Friday, May 21st, 2010 AT 5:40 PM
  • EXPERT
Hi there,
Here is a guide to help you see what you are in for when doing the job with diagrams below to show you what it will be like for your car:
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Cheers
Friday, May 21st, 2010 AT 6:42 PM
GIRISH1952
  • 1997 TOYOTA CAMRY
  • 6 CYL
  • 169,000 MILES
Let me say thanks.
I saw in your web site about Toyota Camery 1997 how to open cabin air filter.
As described I have opened cover but I do not see any thing there that I can pullout
air filter. Can you please help me?
Once again thanks.
Girish
Friday, August 17th, 2018 AT 3:13 PM (Merged)
  • EXPERT
Some vehicle do not have the filter. Does it look like there is a mount for it?
MOREXZ1
  • 2004 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 49,000 MILES
How to replace my cabin air filter?
Cabin air filter replacement:
1. Open the glove box. Remove the screw with a Phillips-head screwdriver and slide the hook as shown.
2. Push each side of the glove box to disconnect the claws.
3. Remove the filter case from the filter outlet.
4. Remove the filter from the filter case.
5. Inspect the filter on the surface. If it is dirty, it should be replaced.
Installation
Reverse removal procedure.
SUECASB
  • 2003 TOYOTA CAMRY
Front wheel drive.
While changing cabin air filter and cleaning out a mouse nest I broke off a solid piece of something right above the filter, it appeared to be hinged. I left it out and everything seems to be working fine but I want to know what I broke and if it will cause problems by not having it fixed?
KHLOW2008
  • EXPERT
Hi Suecasb,
I am not sure what is broken but around the area, it should be something that is not going to affect anything important.
FORDRACING24
Only thing that is plastic above the cabin air filter is the housing for the fan/filter. This should not cause any sort of problem.
Recommended Guides
