Fuel Filter Replacement
ROHITSPATEL
  • 2007 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 30,000 MILES
What is a reasonable charge to change fuel filter Labor + Part can I do it myself please show me.
Friday, May 1st, 2009 AT 10:05 AM
BMRFIXIT
  • 19,053 POSTS
Fuel filter about $40 and an hour labor =$100 to $120 you can do it yourself the fuel filter is located in the tank with the fuel pump but there is a tap door that ames it easy. Here is a guide to walk you through the steps and the instructions for you car in the diagrams below.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Friday, May 1st, 2009 AT 8:02 PM
BPWIT
  • 2007 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 23,000 MILES
Since the fuel filter is in the gas tank, in the Toyota Camry, does this mean that it is a lifetime filter? If not, how often does it need to be replaced? If it does need to be replaced, why would Toyota place it in such an inaccessible area?
Thank you in advance for your prompt response.
Wednesday, December 4th, 2019 AT 5:37 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi bpwit,
It is supposed to be a maintenance free item but people replace them all the time.
OSCILLATION
  • 2006 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 33,456 MILES
1.I will want to know if after changing the fuel filter it will nice to apply injection cleaning fluid to the fuel tank?
2. At the stage of mileage of my car 33456 miles can the fuel filter be responsible for the car to reduce it take-off?
3. Does the oil enhance the take-off?
4. Can oil service affect the movement of the car?
Wednesday, December 4th, 2019 AT 5:38 PM (Merged)
  • 31,938 POSTS
Hi there,
It is a good idea to add a fuel system cleaner periodically, as far as the other issues are concerned I feel that you may have a transmission problem the fuel system will affect drivability but only due to poor engine performance via misfires and fuel starvation. I would have the transmission inspected if you are having drivability concerns.
Mark (mhpautos)
DEANE FOX
  • 2004 TOYOTA CAMRY
  • 179,000 MILES
I would like to know the location of the fuel filter on a toyota camry SE with the 2.4L engine. Also, would a dirty filter cause a " #3 misfire" code to show up on tester? Engine began running rough couple days after putting 1/2 tank of gas into it which was siphoned from another vehicle we were dropping the fuel tank on to change fuel pump. Spark plugs have been replaced [ iridium plugs ] but problem still exists
Thursday, January 2nd, 2020 AT 8:48 PM (Merged)
  • 52,797 POSTS
No fuel filter will not cause this. The tank does not have to be dropped. You can access from under the back seat.
Fuel filter is on drivers front under the hood down low by the left front tire. Toyota does not reccomend replacement of the filter.
BIGTIMER30
  • 2000 TOYOTA CAMRY
Engine Performance problem
2000 Toyota Camry 6 cyl Front Wheel Drive Automatic
Where is the fuel filter on my 2000 camry and how to change it.
  • 108,179 POSTS
It is near the fuel tank (driver's side I believe). Shouldn't be too hard to replace.
FOSTERS2000
  • 2000 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 138,000 MILES
Where is the fuel filter located and how many are there? Would a plugged fuel filter cause the engine compression to guild-up and glow off the vacuum line that goes into the sensor on the top of the engine?
BMRFIXIT
  • 19,053 POSTS
Check fuel pressure
i would check it for tune up too
DAVID23188
  • 2000 TOYOTA CAMRY
I have a 2000 Toyota Camry and need to change the fule filter but am unable to locate it. Can someone please tell me where it is located?
Thanks.
2CARPRO JACK
  • 11,533 POSTS
The fuel filter is under the rear seat in the gas tank here is a diagram below to help you see.
