1999 Toyota Camry Timing Belt
R-BLANCHARD
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 41,000 MILES
If the timing belt should fail, is there a danger of mashing the valves on this engine?
Do you
have the same problem?
Sunday, March 14th, 2010 AT 6:08 AM
DGK
Your Camry will not damage the engine if it breaks, however you will be on the side of the road waiting for a tow truck if it does go. Replacement interval for your belt is aroung 90k. If you have never changed your T Belt do it. Even though the mileage is low, belts can break from old age. 6 Years is a good rule of thumb for belt replacement on Toyotas.
Monday, March 15th, 2010 AT 5:58 PM
Recommended Guides
