1999 Toyota Camry Lights
LOJOMURPHY
  • 1999 TOYOTA CAMRY
Brakes problem
1999 Toyota Camry 6 cyl 90000 miles
How do you change a brake light on this car. My husband is out of State and I have to do it for my daughter.
Do you
have the same problem?
Tuesday, November 11th, 2008 AT 2:55 PM
ZACKMAN
Remove the carpeting to the side that needs replacing. There should be three screws holding the taillight assembly, 10mm wrench. You should be able to remove the assembly from the car. There is one push tab on the side that may be a little stubborn to come out, just keep wiggling. Once the assembly out, twist the bulb socket and replace the bulb.
Install is reversed.
Tuesday, November 11th, 2008 AT 10:50 PM
Recommended Guides
