1999 Toyota Camry Is this timing belt too loose?
KNUCK1723
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 106,000 MILES
I am helping a friend whose 1999 4-cylinder Camry just started a making really loud knocking, diesel-like noise. It also sounds like the timing belt is flapping against the inside of the timing belt cover. I took the timing belt cover off and found that there is 1.25 inches of free play in the belt. I don't know enough about this engine type (nor does the manual indicate) to know if this is okay. I have a picture showing the free play at http://www.dnsppp.net/nmills/camry
Thanks in advance.
Niles
Do you
have the same problem?
Saturday, February 28th, 2009 AT 9:31 PM
Try adjusting the tensioner
Saturday, February 28th, 2009 AT 9:38 PM
Recommended Guides
