1997 Toyota Camry PO773 Torque converter lock up solenoid
MOWGLI
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 195,000 MILES
I just figured what PO773 code is on a 1997 Toyota Camry. It is the Torque converter lock up solenoid. The solenoid has 2 bolts that can be undone from the top of the car. The solenoid is located behind park neutral safety switch. The plug has a pink with black strip. This is A140E transmission. The problem with the vehicle was the Check engine light was on and the RPM would not drop 300 RPM on the freeway at cruising speed. I only post this answer because the only thing I could find in the web was the lock up solenoid was on the valve body. Toyota calls this solenoid #3.
Do you
have the same problem?
Monday, May 24th, 2010 AT 11:18 AM
MMPRINCE4000
  • EXPERT
Thanks for the info.
Tuesday, May 25th, 2010 AT 8:51 AM
Recommended Guides
