Electric windows quit working?
  • EXPERT
Hi there,
You will have to remove the door trim to test for power at the motor, if the switch is faulty, they are not repairable and will have to be replaced.
Mark (mhpautos)
Saturday, May 30th, 2020 AT 12:04 PM (Merged)
LUKIE999
  • 1990 TOYOTA CAMRY
Electrical problem
1990 Toyota Camry Engine Size unknown Wheel Drive Type unknown Automatic 130000 miles
MY DRIVERS DOOR WINDOW WAS WORKING FINE. NOW IT WILL NOT GO UP. ALL THE OTHER WINDOWS WORK.
  • EXPERT
Hi there,
you will have to remove the trim and see if there is power at the motor, as the system uses reverse polarity there will be power on one wire going up and on the other going down. If no power for up check the switch. If power available check motor and regulator.
Mark (mhpautos)
SUNSHINE101
  • TOYOTA CAMRY
I have a 1990 toyota camry station wagon v6 engine
the power windows and locks stopped working at the same time my husband took a wire and battery charger to bypass and put the window up since of course it was down when they stopped working. We do not know were the relay is located or what the problem is. Could you please help? Any advice would be greatly appreciated.
Sincerely
Connie Insley
2CEXPT
Look for a circuit breaker-probably needs to be reset.
LEFTHANDER1234
  • 1989 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 145,000 MILES
MY window on passenger side front will only go up. But if I run run jumper wire from battery to motor, I can make it go down. Switch only make it go up not down. Also switch on drivers side does not work at all for pasenger side. All other switches work fine.
MERLIN2021
  • EXPERT
A car this old, usually turns out a few wires in the harness that runs from the door to the inside of the car break from bending all these years, if nothing found, if windows work at other switches, switch is probably faulty. Test switch continuity as shown.
https://www.2carpros.com/forum/automotive_pictures/62217_cama_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_camb_1.jpg
LEFTHANDER1234
I need more information on how to trouble shoot it and also how to use the wire guide you sent me. Can I use a jumper wire to make window go down>?
MERLIN2021
  • EXPERT
Test the motor like this, it should operate both ways by reversing the leads.
POWER WINDOW MOTOR Circuit Breaker Operation Inspect the window in the full closed position, hold the power window switch in "UP" position and check that there is a circuit breaker operation noise within 4 to 40 seconds. With the window in full closed position, hold the switch in the "DOWN" position and check that the window begins to descend within 60 seconds. If operation is not as specified, replace the motor. Window Motor Operation Inspect the motor operation. Connect the positive (+) lead from the battery to terminal 1 and negative (-) lead to terminal 2. See Fig. 12 . Check that the motor turns. Connect the positive (+) lead to terminal 2 and negative (-) lead to terminal 1. Check that the motor turns the opposite way. If operation is not as specified, replace the motor.
https://www.2carpros.com/forum/automotive_pictures/62217_cammotor_1.jpg
