Air conditioner not working
MLE875
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • 4WD
  • 128,000 MILES
When I turned on my AC yesterday, it may a loud grumbling noise when turned on high. It's as if the noise gets louder as the AC is turned up higher. I've had considerable AC problems not working Any ideas?
Sunday, April 20th, 2008 AT 4:02 PM
  • 31,938 POSTS
Hi there, If this noise is just with the A/C on i would be checking the clutch on the compressor and the adjuster pulley bearing as a first place to look.
This guide will help us fix it
Mark (mhpautos)
Monday, April 21st, 2008 AT 12:11 AM
VLEYVA
I have a 1993 Toyota Camry 4 cylinder 330,000 miles on it. The heater works, but when I push the button for the A/C it only comes on for few seconds, and then the button starts blinking and the A/C only blasts hot air. I also hear a noise that's not clicking but continuous screeching that doesn't stop even if I turn off the A/C. I've taken it to a mechanic, and they said that the Compressor didn't have any oil. They filled it with oil, checked it and said there weren't any leaks. There's also a good amount of Freon in the car, so they said that wasn't the problem. They also changed the belt to a new one that I had bought because the old one was torn and burnt.
I was wondering what could be any possible reasons/solutions?
Thursday, August 6th, 2020 AT 3:36 PM
This definitely sounds like a belt or pulley issue so the best way to find this is to remove the belt and run the engine and see if it is gone. If it is is then since the belt is new it is most likely a pulley. At that point, you want to reinstall the belt and spray some WD 40 on a pulley one at a time to see when it quiets down. This would indicate the failed pulley bearing.
Here is a guide that talks about other common causes of this. Let's run through all this and let us know what you find. Thanks
https://www.2carpros.com/articles/car-squeaking-noise
Thursday, August 6th, 2020 AT 5:27 PM
KERVYNJIM13
  • 5 POSTS
  • 1997 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 160,000 MILES
The A/C stopped working and we have it hooked up directly so we have a switch to turn on and off for the AC. But the AC stopped and now we do not know what is wrong with it. We do not know if it the compressor or the cable or the fuse box. Also, where is the fuse box inside the car?
Friday, November 27th, 2020 AT 8:44 AM (Merged)
  • 52,797 POSTS
Good evening.
Did you wire power directly to the compressor?
If you did, where did you get the power source?
Did you verify power to the compressor with your switch.
I attached a wire diagram for you to view. Check all your fuses with a test light for power on both sides with the key on.
Did you verify Freon in the system?
KERVYNJIM13
  • 5 POSTS
Yes, I bypassed relay for the power.
  • 52,797 POSTS
Okay, did you verify power at the relay and the compressor?
KERVYNJIM13
  • 5 POSTS
I think it is the A/C controller inside the car where the A/C button is not getting power.
KERVYNJIM13
  • 5 POSTS
Yes, I verified.
  • 52,797 POSTS
Okay.
The next step is to verify the clutch is engaged.
If it is, then we need to check the pressures. Do you have gauges to verify pressures?
DOROTEA
  • 1997 TOYOTA CAMRY
  • 200,000 MILES
Air conditioner does not turn on at all.
Switch does not light up.
But switch stays down when I turn it on, but no light does not turn on.
Thanks for any help you give. Isabel
  • 31,938 POSTS
You need to get the system refrigerant charge pressure tested. If very low the low pressure cut out switch will activate and shut the system down. You may have a leak that needs to be rectified. Get this looked at first.
JUSTINA88
  • 1997 TOYOTA CAMRY
Air Conditioning problem
1997 Toyota Camry 4 cyl Automatic 85000 miles
I had to have the radiator replaced in Camry and the mechanic told me I would have to have the A/C flushed and refilled also. Why would I need to have that done also?
  • 31,938 POSTS
Hi there,
There is no reason to do this, all they need to do is make sure that the condenser is not blocked externally with leaf litter and bugs, you just need to ensure good air flow through he condenser.
Mark (mhpautos)
ALEX151
  • 1997 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 130,000 MILES
The ac pulley on my friends 97 toyota camry seized up the other day so we decided to remove the ac pump. After some searching I found that O'Reilly sold a belt for that year that said it bypassed the ac pulley. But now the air won't blow at all hot or cold. We disconnected the 2 lines coming out of the pump and a plug on the ac and removed the whole unit. But now no air.
CATAFINA
  • 168 POSTS
Sounds like your blower is not working-let me know what's really going on
CAR-MAN145
  • 321 POSTS
I would think it has nothing to do with what you did. Check all the fuses for the blower motor
LUCKYLOU
  • 1997 TOYOTA CAMRY
1997 Toyota Camry 4 cyl Front Wheel Drive 168000 miles
why would ac blow cold only out of the left side vents and warm out of the right side
Friday, November 27th, 2020 AT 8:45 AM (Merged)
  • 31,938 POSTS
One of the vent doors has jammed, this is up under the dash and I would suggest that you get a mechanic to inspect this to confirm the diagnoses.
Mark (mhpautos)
