1997 Toyota Camry
NG_TOY_2008
  • 1997 TOYOTA CAMRY
  • 6 CYL
  • 98,000 MILES
I have Toyota Camry 1997 about 98000 miles. After changing engine oil and the day after that on the morning when I try to start engine to work, and it start bu when I release the gas panel then the engine stop, I try couple times and it still happen like that. Could you please give some advice? Is it a major problem or just minor?
Thank you and best regards
Do you
have the same problem?
Tuesday, August 12th, 2008 AT 2:23 PM
BMRFIXIT
  • EXPERT
Possible idle air control valve need to be cleaned
Tuesday, August 12th, 2008 AT 8:54 PM
Recommended Guides
