1996 Toyota Camry smoke when start after 4 hrs of no runnin
LUISMOND
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • 155,000 MILES
Can you please give a step by step explanation on how to change the valve stem seals of my 96 4cyl Toyota Camry?
Thank you very much
Luis Mondolo
Do you
have the same problem?
Thursday, May 21st, 2009 AT 2:02 AM
KHLOW2008
  • EXPERT
Hi Luis Mondolo,
There are 2 ways of doing it and it is not going to be easy.
!St and normal way is to remove the cylinder head to replace the seals.
2nd way is to remove the camshafts and with regulated compressed air into the cylinders from the plug holes and special tools to remove the valve springs and replace the seals.
It would involve removing the timing belt.
Sunday, May 24th, 2009 AT 1:46 PM
Recommended Guides
