1996 Toyota Camry runnung
MIGLI
  • 1996 TOYOTA CAMRY
Engine Mechanical problem
1996 Toyota Camry 4 cyl Two Wheel Drive Automatic
I re[laced the MAP sensor as well as the fuel pump. When the car idles it is very smooth. I ease on the gas peddle it runs great. When I push the peddle down the rpm goes to about 1200 and the car hesitates like it is being choked out or fludded. What should I look at next?
Do you
have the same problem?
Friday, September 10th, 2010 AT 4:44 PM
Vane Airflow Meter and throttle position sensor
Friday, September 10th, 2010 AT 5:42 PM
Recommended Guides
