1996 Toyota Camry Catalytic Converter
BRAVEST343
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • 134,000 MILES
Dear Bob, Ken, and 2carpros team, My check engine light just recently turned on. A new catalytic converter was recently installed on to my camry, but the oxygen sensors were not changed first. I took it to the mechanic and the diagnostic code came back as catalytic converter. What do you think may be wrong with it? P.S.- Now every time I shut off the car after driving a few miles there is a loud ticking noise coming from underneath the vehicle and there is a lot of heat coming from under there. I thank you all in advance for telling me what may be causing these things! I made a 5 Dollar donation today and i'm going to continue to donate. This site is GREAT!
Do you
have the same problem?
Sunday, June 29th, 2008 AT 9:39 PM
The oxygen sensors might not be switching properly and causing the converter to lit up the unburned fuel creating all that heat-
Causes Of Converter Failures
Fouling, clogging, melt-down and breakage of the ceramic substrate inside a converter are common conditions that can cause problems. Plugging is usually the end result of a melt-down, which occurs because the converter gets too hot. This happens because the engine is dumping unburned fuel into the exhaust. The excess fuel lights off inside the converter and sends temperatures soaring. If it gets hot enough, the ceramic substrate that carries the catalyst melts.
The unburned fuel may be getting into the exhaust because of a bad spark plug or valve, but an overly rich air/fuel mixture is another possibility. In older carbureted engines, a heavy or misadjusted carburetor float may be the underlying cause. But on newer engines with "feedback" carburetion or electronic fuel injection, the engine may not be going into "closed loop" (the normal mode where the computer regulates the air/fuel mixture to minimize emissions).
A bad oxygen sensor or coolant sensor may be giving the computer bogus information. A sluggish or dead O2 sensor will make the computer think the exhaust is running lean, so the computer will try to compensate by making the fuel mixture rich. A coolant sensor that always indicates a cold engine will also keep the system in open loop, which means a steady diet of excess fuel. But it might not be the sensor's fault. A thermostat that's stuck open or is too cold for the application can prevent the engine from reaching its normal operating temperature. So if your converter has failed and needs to be replaced, the engine should be diagnosed for any underlying problems before the new converter is installed.
Another cause of converter clogging and contamination is excessive oil consumption. Worn valve guides or seals can allow oil to be sucked into the engine's combustion chambers. The same goes for worn or damaged rings or cylinders. Oil can form a great deal of carbon, and metals present in the oil can contaminate the catalyst. A compression check or leak-down test will tell you if the rings are leaking, while a fluttering vacuum gauge needle will help you identify worn valve guides.
Monday, June 30th, 2008 AT 9:48 AM
Recommended Guides
