Timing belt broke
SEAP
  • 1995 TOYOTA CAMRY
Four cylinder front wheel drive manual 193,000 miles.
My timing belt broke so I bought a new belt and I am trying to time the crankshaft to the camshaft, but I still do not have it right. How is it supposed to be timed? Yeah. If you could give me a step by step instruction that would be great. I have never done this before.
Thursday, October 22nd, 2009 AT 12:43 PM
BMRFIXIT
  • 19,053 POSTS
Here is a guide and the instructions below:
https://www.2carpros.com/diagrams/toyota/camry/1995
Removal:
Disconnect negative battery cable. Raise and support vehicle.
Remove lower engine cover. On Celica and Camry, remove right front wheel.
On all models, lower vehicle.
On MR2, remove right hood side panel and cruise control actuator.
Remove right rear wheel. On Celica and Camry, remove alternator from engine and secure out of way. On Camry, remove coolant reservoir tank if it interferes with timing belt removal.
Remove engine control (torque) rod from front of engine.
On all models, remove accessory drive belts.
Using floor jack, slightly raise engine to remove weight from right (timing belt side) engine mount at timing belt cover.
Remove right (timing belt side) engine mount and bracket from front of engine. Remove spark plugs.
Remove Number two timing belt cover and gaskets. See Figure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_570.jpg
Rotate crankshaft clockwise so cylinder number one is at TDC on compression stroke. Cylinder number one is front cylinder at timing belt end of engine.
Ensure timing mark on crankshaft pulley aligns with "0" mark on number one timing belt cover. Ensure hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Figure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_125.jpg
. If hole in camshaft sprocket is not aligned with alignment mark, rotate crankshaft clockwise one full revolution.
CAUTION: If reusing timing belt, mark direction of timing belt rotation on belt. Place mating marks on timing belt at camshaft sprocket and at crankshaft sprocket for reassembly reference. Also place reference mark on timing belt at upper edge of number one timing belt cover. See Figure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_126.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_275.jpg
Loosen number one idler pulley bolt.
Move No. 1 idler pulley outward, away from timing belt as far as possible. Temporarily re-tighten number one idler pulley bolt. Remove timing belt from camshaft sprocket.
Using pulley holder (SST 09213-54015) or equivalent, hold crankshaft pulley. Remove crankshaft pulley bolt.
Using gear puller, remove crankshaft pulley. Remove number one timing belt cover and gasket. Note direction of timing belt guide installation.
Remove timing belt guide.
Remove timing belt from crankshaft sprocket. Remove idler pulleys (if necessary).
Revised Timing Belt Tension Spring Procedure (1992-96 Camry):
From Toyota technical service bulletin EG001-99; January 29, 1999: For 1992-96 Camry, the timing belt tension spring procedure was revised. When replacing the timing belt on 1992-96 Camry with 2.2L, tension spring MUST be replaced. The revised tension spring 0 (Part No. 905-7-17003) is a 13-coil design which replaces the original 10-coil design.
Installation:
Install number two idler pulley (if removed). Install and tighten bolt to specification.
Ensure idler pulley is clean and rotates smoothly.
Install number one idler pulley and tension spring (if removed). Pry number one idler pulley away from timing belt area as far as possible. Temporarily tighten number one idler pulley bolt. Ensure idler pulley is clean and rotates smoothly.
Using crankshaft pulley bolt, rotate crankshaft so timing mark on crankshaft sprocket aligns with timing mark on oil pump housing. See Figure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_127.jpg
This will position key-way in crankshaft sprocket at 12 o'clock position.
CAUTION:If reusing timing belt, ensure reference marks on timing belt align with reference marks placed on crankshaft and camshaft sprockets.
Ensure timing belt is installed in original direction of rotation.
Ensure all sprockets and idler pulleys are clean. Install timing belt on crankshaft sprocket, oil pump sprocket, number one idler pulley, and then number two idler pulley in sequence.
Install timing belt guide with cupped side away from crankshaft sprocket and flat side toward timing belt. Install number one timing belt cover and new gasket.
Align crankshaft pulley key groove with key in crankshaft.
Install crankshaft pulley. Install and tighten crankshaft pulley bolt to specification.
Ensure timing mark on crankshaft pulley aligns with "0" mark on number one timing belt cover. If reusing timing belt, ensure reference mark on timing belt aligns with upper edge of number one timing belt cover.
Rotate camshaft, and align hole in camshaft sprocket with alignment mark on camshaft bearing cap.
Install timing belt on camshaft sprocket.
If reusing timing belt, ensure reference mark on timing belt aligns with the reference mark on camshaft sprocket.
Ensure tension exists on timing belt between the crankshaft and camshaft sprockets.
CAUTION: Do not rotate crankshaft counterclockwise, as viewed from timing belt end of engine.
Loosen number one idler pulley bolt half turn. Rotate crankshaft pulley two full revolutions clockwise from TDC to TDC.
Ensure timing mark on crankshaft pulley aligns with "0" mark on number one timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap
If timing marks are not aligned, remove timing belt and reinstall.
Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with forty five degree before top dead center (BTDC) mark on number one timing belt cover.
See Figure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic4_56.jpg
Tighten number one idler pulley bolt to specification
Install number two timing belt cover and gaskets.
Install and tighten spark plugs to specification.
To install remaining components, reverse removal procedure.
Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification.
On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic5_34.jpg
Please let us know what happens so it will help others.
Cheers
Saturday, October 24th, 2009 AT 6:39 AM
NANAOF4904
  • 1995 TOYOTA CAMRY
Four cylinder front wheel drive automatic 179,000 miles.
My timing belt broke as I was going down the road. I have asked several people and have gotten several answers. Does the timing belt have to be replaced before checking the compression and do I even need to check the compression because of the engine type? Some said no doubt cause it broke while in motion. My heads are warped. Some said because of being a non, cannot remember word that it would not have warped the heads.
Friday, September 29th, 2017 AT 5:04 PM (Merged)
F4I_GUY
  • 3,302 POSTS
Yes, you must put on a new timing belt before checking compression.
POPTOY
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • 180,000 MILES
Four cylinder two wheel drive automatic 180,000 miles.
What are the chances I have broken valves or valve components as a result of the broken engine. What does resistance engine type have to do with this?
SERVICE WRITER
  • 9,123 POSTS
According to the information I have, this is not an interference engine. There should be no damage to the valves or pistons from a broken belt.
GUNSMOKELN
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 175,000 MILES
Four cylinder front wheel drive manual 175,000 miles.
Is the Toyota 2.2L four cylinder an interference engine?
Timing belt broke.
NYC.ECHO.LEXUS.TECH
  • 20 POSTS
5sfe motor is not interference, pending on how fast the engine was spinning "rpm" you should have no problems.
I have seen some collide with valves, but that was due to high revs when the belt broke.
JOHNNY5STILLALIVE59
  • 1998 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • FWD
  • 120,000 MILES
Timing belt broken. Need to know where the timing marks are?
WRENCHTECH
  • 20,757 POSTS
https://www.2carpros.com/images/external/78901155.jpg_1.gif
JAYLENMIAH
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • 170,000 MILES
Four cylinder two wheel drive automatic 170,000 miles.
I need a timing mark alignment for my car. My timing belt broke and I guess the guys needs the timing mark alignment sheet.
Friday, September 29th, 2017 AT 5:05 PM (Merged)
DSPLC
  • 220 POSTS
On the crank pulley there is a "V" cut out on the pulley, align to zero on plastic cover. On the top pulley there should be a hole in the pulley spokes, behind the pulley you should see a notch (groove), line that up with the hole, use a mirror to look inside the hole aligning to the notch and put timing belt on careful not to turn pulleys.
https://www.2carpros.com/forum/automotive_pictures/89255_timing_1.gif
URBANC71
  • 5 POSTS
  • 1990 TOYOTA CAMRY
  • 4 CYL
  • 200,000 MILES
Four cylinder two wheel drive automatic 200,000 miles.
I changed the timing belt water pump 3sfe engine but no start when the belt broke. Could it have damaged the engine?
Friday, September 29th, 2017 AT 5:07 PM (Merged)
You probably did not set the valve timing correctly. Also, your engine is not an interference.
URBANC71
  • 5 POSTS
I have checked it over and over it looks like it is on time. How would you set valve timing it is very important I get this car running again.
Check if you are getting fuel and spark.
URBANC71
  • 5 POSTS
Okay, I have changed the fuel pump its only getting ten volts at the pump. Is that normal? And when I first turn the ignition on it does not prime the fuel system.
And spark was acting funny so I changed cap rotor wires and coil. Spark is still not strong but it will run if I spray starting fluid in the throttle body. I do not want to trash the car it should run everything I have done with time and money on parts. It wants to run but it is missing something. I was looking at some of the other questions you have answered on no power and no start with the Toyota Camry, but none of them say what the out come was or if they figured it out. When I first changed the timing belt car ran but no power. Now it will only run with the starting fluid. This car is all my family has I have been taking the bus to work walking to the store trying to fix the car. I am getting so stressed over the whole thing. We cannot afford buying a new car at this time. Thank you very much for your time.
Are the injectors pulsing?
MLANDRI1
  • TOYOTA CAMRY
1983 year model, 70,000 miles, four cylinder engine.
About two weeks ago, my car's timing belt broke. I had it towed to the local Toyota service center, where they replaced the timing belt and driver belt for $45000. Just a few days ago, however, my car broke down in the exact same manner as it did when the timing belt broke. I had it towed to the same service center.
However, they are now telling me that the timing belt broke again, but that it is not their fault! Their claim is that my water pump failed and this caused the timing belt to break, which in turn gauged the timing belt cover. They say they will replace the water pump, gasket, thermostat and timing belt cover for $300.00 and throw in the new timing belt and labor on that at no charge.
What should I do? This seems pretty suspicious, and I would like to know if they are really responsible for the second broken timing belt and are just trying to charge me an extra $300.00?
PS: Would they not know if the water pump was ten days away from failing when they repaired the timing belt the first time? And is it even possible that a failed water pump would cause a broken timing belt?
Thanks!
MMPRINCE3000
  • 133 POSTS
It is possible they are correct. If the water pump seized it could break the belt or if coolant got on the belt, it should be changed.
If the AC compressor siezed it could also break the belt.
Normally shops replace only what is necessary, while it may have been a good idea to rotate the waterpump to see if you hear anything, a bearing should make some noise (waterpump), unless they are saying coolant leaked on the belt.
I would simply ask for a more detailed explanation from the as to what caused the second timing belt failure, a seized water pump or coolant contamination.
Still it sounds like they are trying to work with you. You could also check the local BBB to see if they have any/a lot of consumer complaints.
TBILODEAU
  • TOYOTA CAMRY
My car is a 1997 four cylinder. It shut off while I was driving. The mechanic seems to think it is the timing belt though he has yet to remove the engine covers as he puts it to look. He gave me an estimate of $300.00 labor and $92.62 for parts. He claims I need the timing belt ($52.12), an alternator belt ($29.84) and a power steering belt ($10.66). I asked my brother who knows a lot about cars but lives to far away to help me what a power steering and alternator belt are for. He seems to think that I do not need two belts but one the serpentine belt. He said the alternator and power steering, if power steering stands for power steering function by the serpentine belt. Is this mechanic trying to rip me off or are these belts real and I may actually need them? I know what a serpentine belt is and I do not think my needs to be replaced now and my brother can do that when I go to visit him. The timing belt however is broken, I think, the car shut off in the middle of driving with no warning and it will not turn over to start. Also, is this price quote reasonable for a timing belt and labor? Please write me back I cannot afford to donate anything at this time I am really low income and this car stuff is costing me a fortune. Help!
Friday, September 29th, 2017 AT 5:08 PM (Merged)
