1995 Toyota Camry Manifold Gauge Readings
RGLET
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 18,000 MILES
Evacuated A/C sytem for 30 minutes. Got down to 30in Hg. Charged with R134 (30 oz.). Low side gauge reads 20-25 in Hg, Hi side 140 psi. Compressor is running at these conditions. No cold air at all. What problem do these readings point to?
Do you
have the same problem?
Saturday, June 12th, 2010 AT 6:23 PM
Check the blend door if its opening.
Saturday, June 12th, 2010 AT 6:43 PM
Recommended Guides
