1995 Toyota Camry IGNITION CHANGING.
AGNELO
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • 173,000 MILES
After changing the ignition with new keys the wipers work permanently and stop just when I take out the fuse.
I didn't have this problem before.
Best regards
Do you
have the same problem?
Monday, September 13th, 2010 AT 7:09 PM
KHLOW2008
  • EXPERT
Hi Agnelo,
The wiper fuse is hot only when ignition is in start position and you mentioned it is on permanently.
This cannot occur unless it is on permanently ONLY when ignition switch is turned on.
Are you able to control the speed of the wiper?
At what wiper speed is it working?
Either you have a short in one of the wires or the wiper switch is bad.
Wednesday, September 15th, 2010 AT 2:18 PM
Recommended Guides
