Fuel filter
POPSICLECHRISTINE
  • TOYOTA CAMRY
Where is the fuel filter located on a 1994 toyota camry
Sunday, August 27th, 2006 AT 4:33 PM
MIKEYBDMAN
  • 623 POSTS
The fuel filter is up by the brake booster near the front of the car here is a diagrams to show you where and a guide to walk you through the process.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers,
Sunday, August 27th, 2006 AT 4:47 PM
BRENT32
Thank you! I love this site.
Tuesday, November 20th, 2018 AT 10:44 AM
DENNIS FOX
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 200,460 MILES
Where is fuel filter located?
Tuesday, November 20th, 2018 AT 10:44 AM (Merged)
The fuel filter is mounted on the driver side of the engine compartment, below the charcoal canister
https://www.2carpros.com/forum/automotive_pictures/12900_fuel_filter_4.jpg
DEEANN919
  • 1993 TOYOTA CAMRY
Engine Performance problem
1993 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do I locate and change a fuel filter on this vehicle
The fuel filter located under the air intake tube that carries the air to the throttle. Remove that black tube, only 3 screws/nuts and then u see the black filter there. Remove the nut that lies on top of the filter, then the one at the bottom. The bottom one is a bit hard to get to. Then remove the clamp that secures the filter to the car, again only 2 nuts/screws. Replace and reverse directions.
MECONTR
  • 1992 TOYOTA CAMRY
1992 Toyota Camry 4 cyl Front Wheel Drive Automatic 152k miles
where is the fuel filter located on a 1992 toyota camry?
Follow the aircleaner duct before it gets to the throtttle body its right below the duct at driver side-
MOUSA
  • 1990 TOYOTA CAMRY
1990 Toyota Camry
Its located on the driver's side fender well
