Rear left side power window stopped working
MRAHMAN
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 140,000 MILES
Couple of years ago rear left side power window stopped working. Since it was fully closed I didn't bother much. Now the rear right side stopped working, and window won't roll up! Thanks.
Sunday, April 4th, 2010 AT 8:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Can you hear the window motor trying to run when hitting switch? if not they are probably failing one by one.. if so then remove door panel and inspect the window to see what's it's doing when motor is engaged. Lets check the fuses and power relay here are guides to help us fix it. Here are the window wiring diagrams so you can see how the system works.
and
and
https://www.2carpros.com/articles/electric-window-repair
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Saturday, May 30th, 2020 AT 12:01 PM
1KIKOPOWER
  • 1996 TOYOTA CAMRY
My passenger window isn't going up it when down but didn't go up (replaced the motor and passenger switch still wont go up)does anybody now why and what it is I need to do the driver worked fine I couldn't control the passenger from the master switch up or down when I made it worse was when I had a 4 door master switch lying around so I plugged it in and now my locks and windows dont work(everything else works fine) any body now wat I did I checked all the fuses in the dash and under the hood is it a relay I need to replace if so which and were wat did I damage
Friday, February 19th, 2021 AT 7:03 PM (Merged)
MPJ111
  • 20 POSTS
Did you connect all wires correctly, may be it is not properly inserted.
Try unplug and plug it back.
1KIKOPOWER
Yea I did unplug it I damaged something some were but I checked all the fuses so I dont now were to look there no power going to them the light on the inside of the swicth the one that lights up auto doesnt even light up got any clue wat I damaged is there a window and lock relay or hidden fuse?
EDH
  • 5 POSTS
It seems highly impossible with such a newer car but I have a 90 Camry and had problems with my electric windows and door locks and found broken wires between the door and the body. Worth a try!
ERWIN_LEON2000
  • 5 POSTS
No you got a bad fuse some were. Theres not only fuses under the hood and behinde the tray there fuses behinde the panel were the tray is on under the steering wheel remove that paner under the steering weel you see the fuses then remove the black tube were the ac airs goes threw you wont need to remove an screws for that just pull down hard on it you wont brake it it comes right out that way you can get to the fuses behind it you see the 30 a fuse (the bigger kind with the little glass its pink) youll find that that fuse is blown check them all to be sure there good
dum place to put that fuse you dont even now about it youd think theyd put it with the regular ones you can see but then a gain that was a pretty stupid thing you did
thats definatly your problem with out a doubt
ANDREW H.
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 201,000 MILES
So I have a 95 Camry 4cyl LE and the passenger side window does not work, all the other windows work just fine. Now, here is the strange part, when I keep pressing on the passenger side switch eventually its like it will catch and the window will move whichever direction I was pushing the switch however; the switch on the driver side does not work at all for it, only on the passenger side will it move as long as I click the switch many times. Could it be the wires are corroded so it doesn't have a good enough connection?
IMPALASS
  • 3,112 POSTS
Hello
With the miles you have on the vehicle I would think it is the window regulator/motor. The best way to verify is to remove the door panel and disconnect the connector to the motor and then apply 12v to it. If you connect to one way the window will go up and swap them and this moves the window down. If it moves really slowly or not at all, then it is bad and needs replacing. Auto Zone and O'Reilly's carries these parts.
ALEX1991
  • 7 POSTS
  • 1995 TOYOTA CAMRY
  • 4 CYL
I have a 95 camry, but only one window works. Which is a rear right window. I changed the main driver side switch and I still have the same problem. I have ruled out a relay or fuse since one of the window is working. The motors are also good. I am getting voltage at the connector of the driver side switch. I am thinking it would be shortage in the wire, but I think it is too coincidental that the other 3 windows has that same problem. Thank you.
PROTECH1980
  • 901 POSTS
Suspect broken wires in door jamb (inside black dust boot) common problem from years of opening wires become brittle and break, check there.
ALEX1991
  • 7 POSTS
Thank you, but how do I remove the wiring?
PROTECH1980
  • 901 POSTS
You dont want to remove the wiring, just the boot to inspect for broken wires, dont cut it, just feed one end of the boot inside the door exposing wires, then inspect for any broken wires, Also if you have knowledge of auto circuitry and are able to read wire diagrams and know/have a meter I could post a diagram for you, to aid in diagnosing problem
ALEX1991
  • 7 POSTS
That would be perfect if you could post the diagram. Thanks
PROTECH1980
  • 901 POSTS
See below
ALEX1991
  • 7 POSTS
In the same camry, is the window regulator the same on the front and back? I wanted to change the window motor from back to front, but is the regulator the same, even though it is on the same side of the car.
MATT5208
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • FWD
Windows wont go up or down. Door locks wont work and sun roof wont work
Friday, February 19th, 2021 AT 7:04 PM (Merged)
ERNEST CLARK
  • 1,730 POSTS
First check the fuses for each circuit. Also, you didn't say if they won't work at all, or just when you try to control them with the driver's controls. (Do the switches on the other doors work)
Because if the other switches work, then it's probably your door switch is bad, or the wiring that runs through the door to the switch has a break in it.
CRAST
  • 1994 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 200,000 MILES
My back right window wont roll up and the other 4 including the sunroof wont work either. Is it a fuse that has gone bad? It is a year 1995
KHLOW2008
  • 41,815 POSTS
Hi crast,
Problem could be due to a bad fuse, ( POWER FUSE 30 A) or power main relay, both located at relay box on left side of instrument panel.
Other possible causes would be a faulty master switch or wiring circuit.
Check the fuse and relay first.
LFUL2441
  • 1994 TOYOTA CAMRY
  • 4 CYL
  • 355,000 MILES
Seem like I am not getting power to none of my window they will not go up or go down, I throught it was the master switch, I got another one but it did the same thing, window still wouldnt go up or down, need your help please, oh I check the fuses but didnt see a fuses say windows2
