1993 Toyota Camry heating
SUMANDAHAL634
  • 1993 TOYOTA CAMRY
Engine Cooling problem
1993 Toyota Camry Two Wheel Drive Automatic 168000 miles
Hi
My car has problem of over heatin while drive more than 5 minuts. I found that both fan is not working. When I disconnect the fan wair its on and heat goes down. Could you please suggest me what happen in my car.
Do you
have the same problem?
Tuesday, November 11th, 2008 AT 4:18 PM
  • EXPERT
HI there,
One fan is the normal engine cooling fan, the other is the A/C fan, if the standard fan is not coming on, have the fan sensor switch checked, it his is just under the thermostat housing if I remember correctly, If you have not serviced the cooling system, replace the thermostat and flush and flow test the radiator as well.
Mark (mhpautos)
Tuesday, November 11th, 2008 AT 4:31 PM
Recommended Guides
