1993 Toyota Camry fuel filter
DEEANN919
  • 1993 TOYOTA CAMRY
Engine Performance problem
1993 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do I locate and change a fuel filter on this vehicle
Do you
have the same problem?
Sunday, September 7th, 2008 AT 12:20 PM
The fuel filter located under the air intake tube that carries the air to the throttle. Remove that black tube, only 3 screws/nuts and then u see the black filter there. Remove the nut that lies on top of the filter, then the one at the bottom. The bottom one is a bit hard to get to. Then remove the clamp that secures the filter to the car, again only 2 nuts/screws. Replace and reverse directions.
Sunday, September 7th, 2008 AT 1:52 PM
Recommended Guides
