1993 Toyota Camry Car turns but won't start
BCSAILOR
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 190,000 MILES
No sparks but turns. It happened suddenly without any symptom. It ran nice the day before. Checked battery, power to ignition coil, high tension cable resistance, ignition coil primary and secondary resistance, pick up coil terminal resistances and all found as per repair manual.
I also replaced distributor cap and rotor.
Any suggestion? Also where is the igniter and ECM in the car? I can not find. This is 5S-FE engine.
Do you
have the same problem?
Wednesday, September 2nd, 2009 AT 3:26 PM
The fix here is to replace the distributor assy.
Wednesday, September 2nd, 2009 AT 3:59 PM
Recommended Guides
