The car cut off while I was driving
DEEANN919
  • 1993 TOYOTA CAMRY
While I was driving the car cut off and now It will not restart. I'm thinking it may be the fuel pump but not sure any suggestions
Sunday, September 7th, 2008 AT 12:31 PM
LEGITIMATE007
  • 5,121 POSTS
Will it turn over? if not, check connections and terminals for corrosion and cracks.
This guide can help fix it
https://www.2carpros.com/articles/engine-stalls
Sunday, September 7th, 2008 AT 1:02 PM
DEEANN919
Yes but it will not start. I took the back seat out and tried to start the car and the fuel pump makes a whining noiise. I also sprayed carb cleaner in the intake and it still would not start. Don't know where to go from here. Thanks for your help
Sunday, September 7th, 2008 AT 2:21 PM
LEGITIMATE007
  • 5,121 POSTS
If your pump makes a noise then its probably still good, YOur gonna need to check fuel pressure (fuel pressure regulator) and spark.
Monday, September 8th, 2008 AT 12:21 PM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
Monday, September 8th, 2008 AT 12:22 PM
SWIFTY784
  • 1993 TOYOTA CAMRY
  • 268,000 MILES
I have fuel all the way to the fuel filter under the hood if I loosen the out on fuel filter just a eighth of a turn the car will start but not run well cuz the gas is spraying everywhere if I tighten it back up it wont even try to start
Thursday, June 18th, 2020 AT 9:59 AM (Merged)
  • 52,797 POSTS
You need to start from scratch. You need 3 things to run, compression, fuel pressure and spark.
You need a specific amount of fuel pressure to start and is checked with a guage.
From your description, you may have a timing belt failure.
SHARON2034
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 90,000 MILES
Ive had the cars to several mechanics who changed several parts and the car still will just stop running while I am driving. It does this at no particular time.
KHLOW2008
  • 41,815 POSTS
Hi Sharon2034,
Thank you for the donation.
When engine stalled, were the dash indicator light showing?
Does it stall only when slowing down?
What is the iding speed?
When engin stalled, were you able to restart?
What parts have been replaced?
SHARON2034
No lights stalls are on also when coming to stop
1000 RPMS
Yes it will restart, but it sounds like it is starving for gas
Plugs, wires, timing chain, I don't recall if any of the packs were replaced
KHLOW2008
  • 41,815 POSTS
Do you mean it was difficult to restart?
If that is the case, you might have a failing fuel pump which stops intermittently. Check its relay as well.
FOONANAS
  • 1993 TOYOTA CAMRY
  • 6 CYL
  • 225,000 MILES
Car will crank fine but shuts off when you put it in gear. If I happen to keep it cranked while in drive it has little to no power. Where do I start?
KHLOW2008
  • 41,815 POSTS
Hi foonanas,
Start by getting a tuneup done.
FOONANAS
Really. Standard tune up was done 6 months ago. You really think I need to do that again?
KHLOW2008
  • 41,815 POSTS
Anything can happen in six months time.
How long has this problem been occurring?
Is the Check Engine Lamp indicating and have you tried to retrieve for trouble codes?
What is the idling speed?
One of the common cause for loss of performance would be the Mass Air Flow sensor. Get it checked.
JOEYCHENZ
  • 1993 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 160,000 MILES
When I completely stop the car at a stop sign or traffic light, sometimes the engine would shut off. Sometimes when I stop and go on first gear, the engine would want to shut off also, if I kept on gas it more, than it wouldn't shut off but it would be on and off for a second. When I brake kind of fast and then tried to go on first gear, the car would be on and off.
Thank you
BOOSKABEAR
  • 7 POSTS
The description you gave is very vague so it could be a whole lot of things. My first guess however is your torque converter. Your car is getting up there in age and the torque converter might be going bad. It is is sticking then it will slow down the engine because it needs more turning force to start to turn. I suggest taking it to a shop and have them test drive it to see if that's whats wrong with it. If it that is it it will be expensive so shop around
METI1234
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 178,000 MILES
Hi my name is met and I have a 93 toyota camry le that always stalls out after a short period of driving. Wen I start my car or rev it past 4000 rpms the car doesnt try to stall out but after I continue driving a block or two the problem persists and I have to rev again. Can u help me I dont wanna put money into the car for no reason, I already fixed motor mounts for no reason but still problem continue and I got a tune up a year ago. Plese help
ALEXANDERSMAMA2010
  • 20 POSTS
The EGR Valve's are notorious for getting clogged up and needing cleaning or replacement, but that task is about as difficult as just replacing the fuel filter on the car and seeing if that resolves the stalling issue.
We live in Alaska, and have a 93 Camry LE with the EXACT same problems, I cleaned the EGR Valve to no avail so today we are changing the fuel filter.
ALEXANDERSMAMA2010
  • 20 POSTS
Bad news if its the EGR Valve, it cost $180 to replace and it has to be prepaid for because it has to come from Toyota themselves, good news if its the Fuel Filter, it cost $10 and should be in stock at your nearest auto parts store.
