1993 Camry Trouble starting, clicks when turning the key
ABELMANN
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • 131,000 MILES
I am having a hard time starting my car. When I try to turn the key, it simply "clicks". All the lights go on as normal.
I replaced the battery yesterday, as it was rather old and potentially a cause of the problem, but it is still not working OK.
It eventually starts, but only after multiple (anywhere from 3 - 25) attempts.
What should I look for first?
Thanks!
Do you
have the same problem?
Friday, November 6th, 2009 AT 9:19 AM
STEVEW84
You have a bad starter.
Friday, November 6th, 2009 AT 1:00 PM
Recommended Guides
