Where are the knock sensors located
YOUNGMANI
  • 1993 TOYOTA CAMRY
  • 130,000 MILES
3vz-fe engine. The problem is the engine check light turns on while acceleration and stays on, I have had it diagnosed with a malfunction or failure of a knock down sensor. I am thinking of replacing it myself so I was wondering where the sensor was since I do not want to spend a lot.
Monday, November 7th, 2011 AT 9:13 AM
WRENCHTECH
  • 20,757 POSTS
The knock sensor for the v6 engine is under the intake manifold and on the side of the block on the four cylinder. On the v6 you will need to remove the intake to replace the sensor
Here are diagrams of the location for both engines.
Check out the diagrams (below).
Cheers
Monday, November 7th, 2011 AT 11:11 AM
BLUEYES BLOND
  • 6 POSTS
  • 1992 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 152,000 MILES
What is the purpose of a knock sensor and where is it found on the motor and how do u test it to see if its working? Toyota Camry v6 XLE 1992.
Sunday, April 29th, 2018 AT 1:25 PM (Merged)
  • 31,938 POSTS
Hi there,
The knock sensor is located on the top of the block between the cylinder heads (see picture).
Its function is to detect any detention that creates a specific wave length vibration, or more commonly called ping due to incorrect ignition timing, when it sensors this ignition knock it sends a signal to the ECU to alter the ignition timing accordingly this is actually done many times a second and you do not notice any change, to test you can set a timing light up on the engine and watch the timing mark as you lightly tap on the engine block with a small hammer this vibration should trigger a timing change that is visible with the timing light, the timing will re set it self when you stop knocking.
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_60.jpg
Mark (mhpautos)
