1991 Toyota Camry
LILEARS
  • 1991 TOYOTA CAMRY
Engine Cooling problem
1991 Toyota Camry 4 cyl Front Wheel Drive Automatic
my water pump went out so I replaced it the radiator thermastat timing belt car drives fine in town but after u hit the freeway it overheats I flushed the system and checked the thermastat there fine could there be permenent damage from it going out while I was driving.I did notice that there was no movement in the water inthe radiator while it was running
Do you
have the same problem?
Saturday, August 22nd, 2009 AT 4:56 AM
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Saturday, August 22nd, 2009 AT 5:06 AM
Recommended Guides
