1989 Toyota Camry ground wire smokes when cranking over
89CAMRYWAGON
  • 1989 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 183,000 MILES
The ground wire from negative battery to driver side fender would smoke when I try to crank the car.
the ground wire from the cylinder head cover to the passenger side fender does the same thing.
appreciate any diagnostic procedure to determine the cause
is there a device that you can plug in somewhere to deternine the short accurately? If
Do you
have the same problem?
Saturday, October 24th, 2009 AT 2:15 PM
89CAMRYWAGON
Found a blown fuse. All good for now
Saturday, October 24th, 2009 AT 4:02 PM
Recommended Guides
