1989 Toyota Camry Brake & Charge lights come on/go off
REELMAN
  • 1989 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 232,600 MILES
Recently changed serpentine belt. After doing that was driving and the brake and charge lights came on at the same time. Brakes work and car running fine. Lights went off. Thought I would tighten belt a little. Same thing happened. Car starts and runs fine.
Could it be the alternator? Voltage Regulator/diode problem. Also had a problem similar to this with '86 Corolla turned out to be motor(main) relay. What do you guys think any experience with this?
Do you
have the same problem?
Friday, November 14th, 2008 AT 10:42 AM
ZACKMAN
Get your alternator tested.
Saturday, November 15th, 2008 AT 1:08 AM
Recommended Guides
