HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
4Runner
Engine Cooling
Water Pump
Replace/Remove
Toyota 4Runner Water pump replacement
GEOM8TRY
MEMBER
TOYOTA 4RUNNER
I was quoted $800 to replace the water pump on a 98 4runner limited edition 2wd v6. Is that too much?
Do you
have the same problem?
Thursday, July 19th, 2007 AT 5:09 PM
EXPERT
The W/Pump price average between $112.00-$125.00 sounds like too muchy on the labor. Get a 2nd quote.
SPONSORED LINKS
Saturday, July 21st, 2007 AT 4:23 PM
Please
login
or
register
to post a reply.
Related Water Pump Replace/Remove Content
Timing Belt And Water Pump
If I Replace The Timing Belt, Should I Also Replace The Water Pump? And Is There Much More Labor To Replace The Water Pump At The Same...
Asked by
mpollock43
1 ANSWER
23 IMAGES
2001
TOYOTA 4RUNNER
VIDEO
Water Pump Replacement
Instructional repair video
Removal Of Dummy Waterpump
I Have A 1991 Toyota 4runner And The Dummy Water Pump Has Failed, And They Cost Heaps And Was Wondering If I Could Use 2-10inch Thermo Fans...
Asked by
trevor hoult
1991
TOYOTA 4RUNNER
1998 Toyota 4runner Where Is The Noise Coming From
Ok I Have A 98 Toyota 4runner Sr5 L4 Engine, One Of My Firends Told Me That I Have To Change The Water Pump Cause There Was A Noise Coming...
Asked by
chico23
1 ANSWER
1998
TOYOTA 4RUNNER
I Have To Replace The Water Pump. I Am Wonder It Is As...
I Have To Replace The Water Pump. I Am Wonder It Is As Simple As Replacing The Pump Or Do I Have To Take A Bunch Of Stuff Apart To Get To It...
Asked by
Anonymous
1 ANSWER
1 IMAGE
1997
TOYOTA 4RUNNER
How To Change Just A Water Pump
Asked by
Anonymous
1 ANSWER
1997
TOYOTA 4RUNNER
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Coolant Leak Repair
Online car repair manuals
