1999 Toyota 4Runner Check Engine Light
PEPO2K
  • 1999 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 177,000 MILES
After my check engine light went on, it was diagnosed as cat. System efficiency below threshold (P0420).
Replaced the front cat. Converter - light when back on after 6 days
Same code - replaced rear cat converter and sensor - light when on after 6 days
Same code - replaced front sensor - light went on after 3 days
Same code - replaced front cat. Converter again - light went on after 6 days
Could it be the computer?
Any suggestions would be appreciated. It's getting costly at this point.
Do you
have the same problem?
Wednesday, June 3rd, 2009 AT 10:01 AM
TROYISBACK21
Replace all the oxygen sensors
Wednesday, August 5th, 2009 AT 12:01 PM
Recommended Guides
