1989 Toyota 4Runner problems in 4 whell drive
RCRACER74
  • 1989 TOYOTA 4RUNNER
Transmission problem
1989 Toyota 4Runner 6 cyl Four Wheel Drive Manual 203564 miles
If I lock in the hubs and drive in 2high it drives okay. If I drive in 4high or 4low with the hubs unlocked it drives okay. But if I lock the hubs in 4high or 4low the front wheels don't drive, they seem to stammer. When in pavement I can hear the tires chirping. My 4Runner has a 4" lift installed but there was never any problem with 4WD before. I went about two years without putting it in 4WD. I checked the fluid in the transfer case, it is okay. Last year the bearing on the right front wheel was starting to squel, but I greased it and it was fine after that. Any suggestions that I can do in the driveway?
Do you
have the same problem?
Friday, July 11th, 2008 AT 4:17 PM
KHLOW2008
  • EXPERT
  • 42,231 POSTS
Hi RCracer74,
Try unlocking 1 hub and see if there is any noise or tight movement. Try each wheel and see if any difference.
Are the front and rear tires of the same size?
Monday, July 14th, 2008 AT 10:51 AM
Recommended Guides
