Head Bolt torque
GHAMM
  • 1994 HONDA CIVIC
Can you tell me the torque specs. On 94 1.5 head bolts and intake manifold?
Do you
have the same problem?
Wednesday, December 3rd, 2008 AT 7:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Great. Thanks for that.
It looks like there are several engines used in the Civic DX. The engine serial number is located on exhaust side of engine block, below cylinder head near bellhousing. The first 5 characters of engine serial number identify engine type. Please take note of your serial number before following instructions below, although the tightening sequence remains the same, the torque specs are different for each engine type in the Civic DX.
Here is a video to help you see how to use a torque wrench.
https://youtu.be/juOClONIWeY
SOHC ENGINES for Civic DX
Cylinder Head Bolt Specs.:
Engine Type D15B7 & D15B8 :
Stage 1 - 22 ft lbs (30 Nm)
Stage 2 - 48 ft lbs (65 Nm)
Engine Type D15Z1 & D16Z6
Stage 2 - 53 ft lbs (73 Nm)
Cylinder Head Bolt Tightening Sequence
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_12.jpg
Intake Manifold-To-Cylinder Head Nut Specs.:
17 ft lbs (23 Nm)
Cheers
Thursday, December 4th, 2008 AT 12:30 PM
ALFRED AMADO
  • 1994 HONDA CIVIC
  • 1.6L
  • 4 CYL
  • 266,781 MILES
What is the torque sequence for the head bolts, and PSI?
Saturday, November 17th, 2018 AT 11:35 AM (Merged)
  • 31,938 POSTS
Step one 30 Nm Step two 65 Nm.
SKKDKKDK
  • 1993 HONDA CIVIC
  • 4 CYL
  • 226,000 MILES
What is the head bolt torque sequece and ft/lbs of torque on a 93 hond civic 1.5l
OBXAUTOMEDIC
  • 3,711 POSTS
D15B7 and D15B8 Engines
Stage 1 = 22 foot pounds
Stage 2 = 48 foot pounds
D15Z1 and D16Z6 Engines
Stage 2 = 53 foot pounds
https://www.2carpros.com/forum/automotive_pictures/188069_93civicheadtorqseq15L_1.jpg
19AUG43
  • 1996 HONDA CIVIC
  • 4 CYL
  • FWD
  • 80,000 MILES
I just completed a valve job, including re-surfacing the cylinder head. The head bolts were torqued properly according to the Chilton's Repair Manual. My question is: Should the head bolts be RE-TORQUED after the initial run-in period of 500-1000 miles? The Chilton's Manual made no mention of that.
Sunday, February 3rd, 2019 AT 8:37 AM (Merged)
CARADIODOC
  • 33,699 POSTS
Normally not unless the instructions with the head gasket specified differently. Was the head checked for warpage? If it had less than.002" irregularity, resurfacing isn't necessary but it will help the gasket bite and seal better. If there was a lot of warpage, overhead cam heads have to be heated and straightened, otherwise the cam journals will still be out of alignment.
YUNGBLUD316
  • 1995 HONDA CIVIC
  • 4 CYL
  • FWD
  • 320,000 MILES
Hi I was wondering what the head bolt sequence for a 95 Honda civic would be?
BMRFIXIT
  • 19,053 POSTS
1.5l engine
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_618.jpg
1.6VETc
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_294.jpg
HONDA TECH 1818
  • 536 POSTS
CYLINDER HEAD BOLTS TIGHTENING SEQUENCE
Tighten the cylinder head bolts in two steps.
1st step : 30 N Â m (3.0 kg-m, 22 Ib-ft)
2nd step:
D16Z6, D15Z1 engines:
73 N Â m (7.3 kg-m, 53 Ib-ft)
D15B7, D15B8 engines:
65 N Â m (6.5 kg-m, 47 Ib-ft)
SKITZ
  • 1992 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 146,000 MILES
I have a 1.6 16v esi v-tech civic here and I have just stripped the head down to fit a new head gasket. The engine has 146,000km on it. I was looking to know what the torque settings are for the bolts on the head and what is the sequence for tightening them?
Thanxs for all your help :)
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_honda16_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_honda_16_1.jpg
See below
https://www.2carpros.com/forum/automotive_pictures/12900_head1_1.jpg
D16ZE stage 1 22ft lbs /stage 2 53ft lbs see below
https://www.2carpros.com/forum/automotive_pictures/12900_head2_1.jpg
