Timing out of adjustment
RANDY SHARP
  • 2002 DODGE STRATUS
  • 2.7L
  • V6
  • FWD
  • 130,000 MILES
Installed a water pump now when I am trying to adjust my cams with the 3/8 in extension my cam on the right side does not seem to be in the same place because I marked them in the back and I know the right I was going to turn it clock wise and the left counter clock wise bit for some reason now the right bank is in a different place I will have to turn it counter clock wise and that is not the way it was. Does any one know if I can turn the cams to get the cams on there timing marks and the 12 pins. Can I do that with out damaging any thing?
Do you
have the same problem?
Friday, July 29th, 2016 AT 9:33 PM
RIVERMIKERAT
Yes, but you have to do it carefully.
Saturday, July 30th, 2016 AT 8:12 AM
Recommended Guides
