THIS VAN WON'T START BY IGNITION KEY AND WHEN THE ENGINE TURN IT STOPS
GERALD FORTIER
  • 1999 PONTIAC MONTANA
  • 283,000 MILES
OK, THIS GUY ASKED ME TO LOOK INTO THIS PROBLEM, HE HAS A 99 PONTIAC MONTANA VAN AND HE HAD IT PARKED THEN HE WENT TO GIVE IT A BOOST AND SAID SOMETHING BLEW UP ON THE ENGINE, NOW WHEN HE GETS IN THE VAN TO START IT WHEN HE TURNS THE IGNITION KEY NOTHING HAPPENS HE GOES TO THE END WITH THE TURN OF THE KEY AND NOTHING, THERE IS POWER BECAUSE THINGS TURN ON BUT THERE IS NO CRANK ON THE ENGINE, HE GOES UNDER THE VAN AND TRYS TO START IT BY TOUCHING SOMETHING TO THE STARTER AND THEN THE VAN STARTS BUT THE ENGINE QUITS RIGHT AWAY,
HE CHANGED THE SELENOID ON THE STARTER AND IT WASN'T THE ISSUE, WHAT DO YOU THINK THIS IS?
Do you
have the same problem?
Monday, September 16th, 2013 AT 8:18 AM
HMAC300
  • EXPERT
Check the three thing sin the pic then check to seeif poer is going through neutral witch. The fusible link may be blown however.
Monday, September 16th, 2013 AT 10:47 AM
Recommended Guides
