The engine wont start after full acceleration by the car
TAREKPRO
  • 2001 VOLKSWAGEN PASSAT
  • 1.9L
  • 4 CYL
  • TURBO
  • FWD
  • MANUAL
  • 400,000 MILES
VW passat 2001 1.9 tdi avb 3bg: the car accerlerated sudnly over 5000 rpm then the engin stopped when the car is running at 80 km/h, after that the engine won't start : the sound when I want to start the engine is like an engine with bad valve timing, need help please, maybe ecxessive oil in the combustion chamber?(Turbo hs? Pistion ring? Valve?) And sorry for my bad english
Do you
have the same problem?
Saturday, June 28th, 2014 AT 8:25 PM
EXOVCDS
Yes, the engine probably sucked excessive oil (that collected in the intercooler) and "ran away". Resulting in a hydrolock & bent valves.
You need to do a mechanical inspection of the camshaft / crankshaft timing. Most likely the cylinder head will need to come off to repair the engine damage.
Thomas
Sunday, June 29th, 2014 AT 10:13 PM
TAREKPRO
Thank you verry much thomas, i'll do the mechanical inspection and tell you whats really happend take care :)
Monday, June 30th, 2014 AT 11:54 AM
Recommended Guides
