The car cranking but did not start
FADY2004
  • 2000 GMC JIMMY
  • 150,000 MILES
The car cranking but did not start I went to mechanic and change the computer(PCM) after two weeks the same problem happened I went back to the mechanic and he replace fuel pump, the relay, and the fuel filter after that the same problem happen yesterday 4 times but after I disconnect the negative battery cable and put it again the car start now the car working but I am not apple to drive it because once the car start it will not stop while I am driving but when I shut the car off and when I want to turn on it it might don't start. After I search on line I think the alarm system. If the alarm system the cause of this problem How I can remove it from the car
Do you
have the same problem?
Thursday, October 17th, 2013 AT 4:47 AM
  • EXPERT
Is the anti theft light coming on?
Thursday, October 17th, 2013 AT 9:49 AM
Recommended Guides
