TDC sensor code
VIGOR94
  • 1994 ACURA VIGOR
  • 2.5L
  • 5 CYL
  • 293,200 MILES
Installed new distributor after removing original oil soaked in cap. Ran For sixty miles then car stalls at stop sign or red light. Then day later starts then shuts off. Restarts and will not idle, period. Check engine code is eight flashes. Shows TDC sensor.
Do you
have the same problem?
Monday, January 29th, 2018 AT 7:07 PM
  • EXPERT
Can you post the actual code set? This will help with the diagnostics.
Wednesday, January 31st, 2018 AT 1:39 AM
